pen assembly issue
  1. M
    Pen Blank a Skosh too Short
    Hello. I read the couple of threads here that a search on "short" yielded on this, but I am still not sure how to proceed...or if I even can/should: I bought some cast acrylic pen blanks with tubes pre-inserted for 30-caliber bullet-style pens. To avoid blowout I don't use a barrel trimmer...
  2. ramaroodle
    Library correction??
    FYI - Confusing but...The Rockler Manhattan Elegant kit #46997 is the same as the Rockler Sierra Vista kit with bushings measuring .551 & .523 In the app the instructions for the Manhattan Elegant are a copy of the regular Manhattan kit #47863. The regular Manhattan takes the same bushings...
  3. J
    Breaking down a pen
    I recently put together a cartridge pen; however, I noticed that I forgot to put in a little copper sleeve that is needed for the click side to work. Is there anyway to take a pen apart without damaging it after it has been pressed together?
  4. R
    Gatsby Pen Assembly Issue
    After assembling the Gatsby V2 pen, I cannot get the mechanism to work correctly, so have to just leave the pen tip out. When I screw the top mechanism in all the way, the tip goes out 3/8 of an inch and won't retract. I see a thread in December where someone had the same issue. There were about...
