Set up: HPM283fdw Color Laser Printer, Onlinelabels Weatherproof Polyester Laser sheets, 600dpi, printing on label paper selected, brass tube, Alumilite Clear
Issue: Everything turns out fine up until I finish the pen. It seems the heat generated with sanding/buffing is causing an issue with...
