mold making
  1. Dustman
    Silicon vs. HDPE Molds
    I am just getting into making my own blanks. I'm looking for opinions regarding pros and cons of silicon and HDPE molds.
  2. D
    Multi-cast Resin Mold
    At one point online, I ran across a site that had a ton of different multi-cast molds that after casting both parts would result in a resin segmented style pen. For the life of me, I can’t find it now. There were over 10-20 different molds for casting…and my husband says if I can’t figure out...
  3. P
    Resin saver mold for dragon pen
    I'm looking for molds, with cork ends, for PSI dragon twist pen. Anyone have instructions on how to make the molds? Can I buy them anywhere?
  4. Lenny
    Gearing up to try casting PR
    I received my gallon of Silmar41 today along with a set of transparent pigments from U.S. Composites. Was a little surprised that they are liquids. (which I guess shows how little I know):confused: Will these work and what should I expect for results or what should I be aware of for pitfalls...
  5. L
    Cigar Pen Northern Lights
    My first Cigar pen casting name "Northern Lights" Emerald Green with gold micca swirl comments welcome. Mold use is from " thepenwizard.com ":biggrin:
  6. L
    Mini Review Euro Pen Mold From ThePenWizard
    First I like to say I was giving this euro mold to field test it by Joe Swall The Pen Wizard . I must say it works really easy and you save alot of resin using his molds plus no drilling is require because rubber stoppers block resin from entering tubes. The amount of resin use was 2 oz. for...
  7. L
    Postage Stamp Gatsby Pen First Cast
    Here's my first PR casting done using .44 cents Christmas Postage stamps. The mold use was a Thepenwizard by Joe Swall Gatsby Mold and I must say using this design with rubber stoppers on the ends of tubes is the ticket, Nice mold can't wait to try my cigar mold next, Comments welcome !!!:biggrin:
  8. leestoresund
    8th SE Chapter Demo
    As promised, here are photos of the mold made. It was put in the car before it had properly set and was slightly unlevel. When I got home I put it on a level surface and filled the coffer dam thus leveling out the base of the mold. Worked great. You can see the additional silicone, it's the...
