laser inlay
  1. W
    Segmented Acrylic
    I wanted to see if I could use the laser engraver to segment acrylic, so I picked Syracuse's logo in blue and organge from PSI. I drilled them out, turned them round, then cut out an S from the orange blank. I then offset my image by .007 to account for the material the laser would remove and...
  2. W
    Casting a Laser Cut Wood Blank
    The odd things you come up with when you mix together different parts of the hobby. This was my first attempt to cast a pen blank that I had cut with a laser. I just used silmar 41 and coastal scents orange glitter. I did the casting upright in a pill bottle. I should have used my sierra mould...
  3. W
    Navy Blue and Yellowheart Warfare Pen.
    I made this from a Navy Blue blank purchased from The Village Workshop and a piece of Yellowheart from a lumber supply place in Seattle. It took a bit of trial and error to get the engraving to the right depth so I didn't turn/sand off the engraved lines when I assembled it for final turning and...
