I have gotten my Dirll chuck stuck in my headstock morse taper after a first attempt at a pool cue. I have already tried using a knock-out bar but it has also gotten stuck as the drill chuck has a hole in the back. I also tried WD-40, a little heat, and twisting it with no luck.
Does anyone have...
Hello,
I'm looking to replace my mini wood lathe with a Sherline metal lathe, in order to be able to work with metals and make more accurate cuts as well.
I'm planning on drilling in woods, plastics, rubbers, as well as non-ferrous metals like Aluminum and Brass for my kitless work.
I saw that...
The question arises again:
Drill Press
or
Drill Chuck for the lathe
Okay, here's the rub... The press can be picked up immediately, in-store. It's versatile, as in I can drill all sorts of stuff--however, I haven't, to date, had great need for a drill press--though it has come up...
I bought a drill chuck from AS and am using it for the first time in my Turncrafter Pro lathe. I noticed it seems to be too long. I have seen people shorten them in other posts. What is the easiest way to do this and about how much do people take off? Thanks
I have a drill chuck that has a J33 to MT2 arbor. However it will not accept a drawbar and it works it's way loose while drilling sometimes. I would like to buy a new arbor (Little Machine Shop term) with one that will accept a drawbar. Little Machine shop lists two, a long one and a short...
