nsfr1206
Can someone tell me how or where to look to get some info on multi start threading on a metal lathe? Thanks. David
Start here
http://www.penturners.org/forum/showthread.php?t=53114
Edited in. For future reference you might want to bookmark this link. It is a thread on triple threading on the lathe by one of the best ..."SkipRat"
Start here
I've just finished making a PowerPoint Presentation using SkipRat's posts and it much easier to following that opening each of his 25 pictures. Not able to upload it yet, but if you'd like a copy I can send it to you via e-mail.
Barney
Start here
Barney
I'l take one. Thanks
Start here
Barney
OK, everyone.....I've been able to add the PowerPoint Presentation to this post.
Check it out and see if it works for you.....let me know how you like it.
Barney
I must be missing something... How does the procedure insure that thread 2 and thread 3 start 60 degrees from thread one??? (evenly spaced around the diameter)??? Needs more info around slide 20...unless I'm fouled up... which is very possible...
Tom
Slide 20 say to advance by 1mm for the second thread. And by another mm for the third thread. That will make the threads 1mm apart and starting 60 degrees from each other.
Barney
PS. Replaced the PowerPoint Presentation with another one to make slide #20 clearer. Hope it helps!
