Who manufactures plastic pen blanks?
geep
Esterhazy SK
and by plastic I am referring to the acrylic and other plastic types that are commonly sold by pen making suppliers?
Are they made in large sheets and then ripped to size, are the colors/styles duplicated from one batch run to another or are they random occurrences etc?
If anyone could steer me in the correct direction..............
Yes.
Meaning it depends. There are large makers and small makers.
The big makers sometimes make them in large sheets that are then cut up. I think Ed has posted pics of some of the stuff he imports from Europe. they have very specific techniques for each blank, so they can repeat it.
The small makers work in smaller batches. so you can see greater diversity in a few blanks. Dawn's single colors for example are made in molds that make 3 at a time, that Ed then cuts apart. The batch she made yesterday might be slightly different than the same batch she made a week ago, but they will be close.
When I was casting, I used a 9 inch square pan, so I could get larger numbers from each run.
If they are round, usually they were cast in rods (for Exotics, this is the alternative series). If they are square, they were made in sheets (about 42" x 28" from Italy).
I specify how thick they will be---usually 20-22mm.
Paul
Tell us what it is you want to know. Do you want to buy pen blanks or do you want to buy sheets or rods or what is that you are after??? Then I think someone can do the driving and steer the car without hitting those roadblocks. :)
Me.
A hinted at in previous posts, there is a huge variance in price depending on the quantity / style / waste / finish.
For example, I can make 1 one-off as simple or as complicated as I like, dead cheap, but to duplicate it again will be expensive. The more complex ones will be in a square mould, which is easier to work, but incurrs about a 50% loss just in roughing round! I can cast in tubes, but these tend to be quite simple (solid colours, gentle swirls).
I tend to make sets of 3, which can be sawn into individual blanks, but again, these are difficult to replicate if they turn out to be popular. But they're a nice middle ground. I have several if they're good or if I trash one, but not so many that it's an expensive waste if they're not great. Also, swirling patterns in polyester is not easy. It's time-critical and that time is quite dynamic depending on a lot of environmental conditions. Consequently, certain blanks require me to sit over them for half an hour twiddling my thumbs waiting for the appropriate moment to swirl!
My biggest single blank was for a set of 12. These were for a customer. It was a sucess, but I only used the mould once: if I were to make a set of 12 and they turn out unpopular, that would be a total loss.
The result is that blanks can cost anything form $4 to $12.
Paul
Actually just an inquiring mind wanting to know , nothing more nothing less:wink:
