wdcav1952
Activities Manager Emeritus
OK guys and gals, it is time for our First Annual July Independence Contest!!
This contest was suggested by our very own Master Scroller Jeff Powell, known to one and all as workinforwood. Jeff is putting up some of his totally awesome scrollwork blanks as the grand prize for the winner of this contest. We are working on some runner up prizes and will announce them later.
The formal name for the contest is The Casing Pen Challenge. Jeff wanted to keep the rules simple so here they are:
You must use at least the first 3/4" of a 30-06 or 308 casing. This is the section that a bullet would press into. You can use the entire casing, or multiple casing. You can use any kit parts to combine, as well as any other alternate materials. The only true rule is that first 3/4" of the casing must be used and it must be a real casing, not a man made on a lathe piece of brass.
After much discussion, Jeff and I decided to allow our Brit members to participate even though the contest celebrates our independence from their tyranny!! :curse::biggrin::biggrin::biggrin:
The contest will start on July 1st and run through the 31st. At that time, a secret panel of judges will pick the top 5 casing pens. The IAP members will vote on these pens to determine the winners.
I will open a thread in which to post the pens on July 1st. Post your pen with as much detail/bragging as you like. This thread will be ONLY for posting pens, no NPGJ posts will be allowed. Repeat, if you don't enter a pen, you can't post on the contest thread.
Now, here is the fun part!! If, and only if, you post a pen in the contest, you can trash talk about your fellow contestants as much as you like, remembering the rules for decorum on the site.
Alright all you casing pen artists, get to planning!!!
