low_48
Just finished converting my back up Jet mini lathe to a powered rose engine lathe. These are the first objects off the new machine. My designs are horrible, but wanted to get something to the lathe to see how it will work. The first two items are boxes, (that second one should be on top of a 4 poster bed instead of a box) the third is the bottom of a spinning top (you have to take my word for that?) I have to change the design of the pattern wheel a little to get better tracking, but I felt really good about the first runs. There will be more to follow as I hope to be able to market a kit for others to convert their lathe. I did not sand the cuts, that is straight off the cutter. Kinda tickled with the results. Next project should be a pen.
