BillyBoy63
Thinking about buying this pressure pot form TCP Global Corporation
in the product description it says 90 lb. max pressure
and the safety relief valve is set to 60 psi
what would you up grade the safety valve to
someone here said they use 70 psi to cure there pen blanks
I though about a 80 psi or 90 psi valve
what do you think
http://www.penturners.org/forum/attachment.php?attachmentid=167061&stc=1&d=1503424782
