Need help guys
magpens
Canada
Here is a link to a table that I use all the time. . I keep the link on my desktop.
Drill Size Conversion Table
Looks to me like a 25/64" would do the trick, but the hole will be very slightly undersize.
JimB
West Henrietta, NY, USA.
A 25/64 is the same as a 10mm. I use this link a lot: Millimeters to Inches (mm to in) conversion calculator
It's actually not the same. That converter is telling you the closest fractional size only and does not include letter bit sizes. In this particular case it works because that is the closest but in other cases it may not be the best choice. The table linked above gives better information for choices.
Rockytime
Arvada, CO 80003
Lots of drill conversion aps for both Apple and droid to be downloaded. I refer to them all the time. Always there when I need it.
Beautys_Beast
Wisconsin/
But a 10mm tube will fit in a blank drilled with a 25/64 bit. I have a 25/64, and the package says 10.0 mm (25/64) Ordered it from PSI
